Всем привет.Появились ошибки,что они означают?можно ли обойтись без поездки к официалам?
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 BF HW: 8K0 907 379 BF
Component: ESP8 front H04 0030
Revision: -------- Serial number: --------------
Coding: 050500
Shop #: WSC 06325 000 00000
VCID: 7EF9E021E9EC549
2 Faults Found:
00285 - ABS Wheel Speed Sensor; Front Right (G45)
012 - Electrical Fault in Circuit - MIL ON
Freeze Frame:
Fault Status: 11101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 152
Mileage: 81518 km
Time Indication: 0
Date: 2015.05.24
Time: 15:25:16
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x07A2
Hex Value: 0x0007
Hex Value: 0xC099
Hex Value: 0x00FF
00473 - Control Module for Elect. Park/Hand Brake (J540)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 152
Mileage: 81518 km
Time Indication: 0
Date: 2015.05.24
Time: 15:25:16
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x07A2
Hex Value: 0x002E
Hex Value: 0x0299
Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 CL HW: 8K0 907 064 CL
Component: BCM2 2.0 H05 0435
Revision: 00002001
Coding: 010100
VCID: 7CFDEA29FFF0469
Subsystem 1 - Part No SW: 8T0 959 754 HW: 8T0 959 754
Component: FBSAUDIB8 IDG H60 0072
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
1 Fault Found:
02823 - Requirements for Locking the Steering Column Lock not met
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 152
Mileage: 81524 km
Time Indication: 0
Date: 2015.05.24
Time: 17:00:17
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H17 0014
Revision: -------- Serial number: 90372KA6000LS
Coding: 000012
VCID: 3D7B272DA46A8F1
Component: E221 - MFL H02 0010
1 Fault Found:
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 6
Fault Frequency: 10
Reset counter: 152
Mileage: 81518 km
Time Indication: 0
Date: 2015.05.24
Time: 15:26:15
Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000704234
Shop #: WSC 00000 000 00000
VCID: 346D020997204E9
3 Faults Found:
02427 - Brake Disk Right Rear; Not Reached
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 192
Mileage: 81524 km
Time Indication: 0
Date: 2015.05.24
Time: 16:58:37
Freeze Frame:
Voltage: 12.50 V
Count: 1
Speed: 0.0 km/h
Hex Value: 0x0270
Hex Value: 0x0008
Hex Value: 0x1008
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Status: 11101101
Fault Priority: 4
Fault Frequency: 1
Reset counter: 152
Mileage: 81518 km
Time Indication: 0
Date: 2015.05.24
Time: 15:27:01
Freeze Frame:
Voltage: 12.30 V
Count: 62
Speed: 0.0 km/h
Hex Value: 0x0273
Hex Value: 0x0001
Hex Value: 0x1010
03199 - Actuator for Electric Parking Brake; Right
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 1
Fault Frequency: 1
Reset counter: 192
Mileage: 81524 km
Time Indication: 0
Date: 2015.05.24
Time: 16:51:21
Freeze Frame:
Voltage: 13.20 V
Count: 5
Speed: 0.0 km/h
Hex Value: 0x02F0
Hex Value: 0x0001
Hex Value: 0x0208
Parking brake malfunction!
Автор sergei81, Май 25 2015 18:31
В теме одно сообщение
Отправлено 25 Май 2015 - 18:31
Отправлено 26 Май 2015 - 15:13
К официалам не обязательно. Можно провести диагностику и ремонт в любом нормальном сервисе. Начать с датчика системы abs.
