VCDS Version: Release 805.3
Data version: 20090213
Monday,27,April,2009,20:33:10:25034
Chassis Type: 7L - VW Touareg
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGZZZ7LZ5D055050 Mileage: 48510km/30142miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 070 906 016 BL HW: 028 101 185 9
Component: R5 2,5L EDC G000AG 7001
Revision: 12345678 Serial number: VWZ3Z0D3291861
Coding: 0001175
Shop #: WSC 66565 257 00032
4 Faults Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 000 - - - Intermittent
Freeze Frame:
RPM: 1008 /min
Torque: 61.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.63 V
Bin. Bits: 00001111
Bin. Bits: 11000000
(no units): 1.0
16683 - Boost Pressure Regulation: Control Range Not Reached
P0299 - 000 - -
Freeze Frame:
RPM: 2898 /min
Torque: 427.0 Nm
Speed: 81.0 km/h
Load: 66.7 %
Voltage: 14.14 V
Bin. Bits: 00001000
Absolute Pres.: 2499.0 mbar
Absolute Pres.: 1621.8 mbar
16497 - Intake Air Temp. Sensor (G42): Signal too High
P0113 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 183.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.08 V
Temperature: 133.2°C
Temperature: 65.7°C
Temperature: 40.5°C
16622 - Manifold Pressure / Boost Sensor (G31): Signal too High
P0238 - 000 - -
Freeze Frame:
RPM: 798 /min
Torque: 56.1 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.86 V
Bin. Bits: 00001111
Absolute Pres.: 887.4 mbar
Absolute Pres.: 2182.8 mbar
Readiness: 0 0 X X X
Меняем датчик температуры и датчик давления наддува?
ЗЫ: 16683 - это из за того что мы его отключали ИМХО
